-   -   Anyone ever try the BBC trick flow intake manifold? 540-565 ci (https://www.offshoreonly.com/forums/general-q/360155-anyone-ever-try-bbc-trick-flow-intake-manifold-540-565-ci.html)
SB 04-24-2019 11:52 AM
Originally Posted by Baja Rooster (Post 4683658)
With all of these spacers it seems like we're just getting back to the venerable tunnel ram. ;)
You can add 4" of spacers or more and it's still not a Tunnel Ram.
Just like adding spacers to a dual plane is not making a single plane.
Making something share 1 characteristic does make something become another.
payuppsucker 04-24-2019 01:39 PM
https://rehermorrison.com/product/an...ersion-plates/
These made an extra 8-12 horsepower on my 540s.
articfriends 04-24-2019 02:37 PM
Most these bigger motors if you add a tunnel ram to dyno sim it shows signifigant gains with virtually no torque loss. I have never built a motor with a tunnel ram or dynoed one with one but i plan to!
SB 04-24-2019 04:36 PM
Dart Tunnel Ram. Trust me. Famous last words !ha,ha,ha.
14 apache 04-25-2019 08:29 AM
Almost did the dart tunnel rams but ended up going kinsler injection off class one race motors with new ecu's don't think it cost that much more with used intakes.
Wildman_grafix 04-25-2019 09:10 AM
How well would a tunnel ram work with a boat motor? I always assumed from my old car days the low end would suffer to much in a single speed boat.
payuppsucker 04-25-2019 09:13 AM
https://cimg2.ibsrv.net/gimg/www.off...4c6d5718b.jpeg
Richie Zul did quite a few of them so I'm thinking they work pretty well.
hogie roll 04-25-2019 09:39 AM
That depends on runner Csa and length. Sized properly they will always be better due to the straighter line to the valve.
SB 04-25-2019 09:41 AM
And all Dart's :)
Back then, we didn't have 500cid-700cid engines running around everywhere. Also,todays cyl heads and hyd roller cams are lightyears ahead. Bolt on 400cfm raised runner heads to your door as quick as you type in your cc #. Amazing world we are in.
Lastly, a certain tunnel ram isn't the same as the net. Runner cross sectional area and length and plenum volume all determine what rpm vs cid vs power it ill make. Same with single pane intakes...thus why it drive's me nuts (single plane intake manifolds mostly) when talked about generically.
Another thing is, people back then didn't really realize the different timing requirements of the tunnel rams. They typically love a ton of initial timing.
Baja Rooster 04-25-2019 10:52 AM
Thats sort of my point. Growing up I only saw tunnel rams on jet/V drive boats and never on a street car because they were too “radical”. Technology has improved so much that now we’re adding spacers upon spacers to single planes creating a bastardized version of a tunnel ram without the benefit of better fuel distribution.
I think given the advancements of engine building the tunnel ram may be a good option again.
