****Need Help**** 496 MAG HO CAM Specs >
Like Tree7Likes
Old 04-16-2019, 03:42 PM
Default ****Need Help**** 496 MAG HO CAM Specs
Has Anybody had a cam ground close to the MAG HO specs or have the Full spec available so i can get a custom grind so i dont end up with regurgitation. thanks in advance
rezmedic is offline
Old 04-16-2019, 05:07 PM
SB
I don't have the cam specs but I've actually found less beers and/or less bumps helps with less regurgitation.
SB is offline
Old 04-16-2019, 05:11 PM
My Boat: 280 Velocity
Do a search on this site. The specs have been posted before. Raylar also sells a cam that is a touch bigger than stock that will work with the stock pistons
underpsi68 is online now
Old 04-16-2019, 05:30 PM
I looked im sure its there i just cant find it.
i already bought raylars pistons, rods,crank. just dont want his cam..plus comp will grind for $300 instead of $600 and i have the Motorola computer Mark at precision marine recommended mag HO cam for ease of tuning . just looking for specs so i can get close with a custom grind, and so i can save a few bucks.
rezmedic is offline
Old 04-16-2019, 05:39 PM
SB
1st Google Woogle search and BAMM !
https://www.offshoreonly.com/forums/...6ho-cam-2.html
rezmedic likes this.
SB is offline
Old 04-16-2019, 05:48 PM
So your doing a stock rebuild basically?
Old 04-16-2019, 05:55 PM
basically someone borrowed my deck boat and grenaded my engine, 18k total 6k labor, 12k for a long block or $4000 for raylar stroker kit rocker arms etc and my time, just figured out the cam i bought has wrong everything. just looking to get close so i can get on the water with the family after 5 years trying not to get ripped off. done plenty of LS1 hotrod builds, but this is my first marine engine and i finding out there are some learning curves with marine.
rezmedic is offline
Old 04-16-2019, 05:57 PM
I appreciate everyone help
rezmedic is offline
Old 04-16-2019, 07:42 PM
My Boat: Baja 342 Raylar HO 600's
If you have forged pistons with reliefs just use a 741 cam specs. It would be bigger than the HO cam and smaller than his 600 cam.
Keith Atlanta is offline
Old 04-16-2019, 08:45 PM
I do have forged pistons with valve reliefs...I donít have dry exhaust... still using factory exhaust, thru outdrive unless Iím missed something need bottom
rezmedic is offline
OSO Sponsor
OSO Advertiser
OSO Advertiser
OSO Advertiser
