-   -   525EFI cam sensor (https://www.offshoreonly.com/forums/general-q/360448-525efi-cam-sensor.html)
fastlane40 05-06-2019 03:16 PM
The 8.2 Ramjet was EFI wasn't it?
What did it use?
fastlane40 05-06-2019 03:20 PM
1 Attachment(s)
Maybe it didn't have one?
Attachment 576362
F-2 Speedy 05-06-2019 03:24 PM
Merc's 500 EFI 8.2 no crank sensor HEI ignition not coil on plug like the 525, and the HP 500 was carb 8.2
SB 05-06-2019 04:23 PM
Attachment 576362
On pg 18 of that PDF is shows the Ramjet502 uses the external coil computer controlled HEI. So, no cam sensor.
Qestion for you guys that have or are intimate with the 525eFI, is the timing cover steel/aluminum or plastic/nylon ?
