Engine Cutting out
Hi, now I can't get the engine started. Its so simple but I can't figure it out. I have fuel, the motor is turning over but won't run. It seems like its trying but just never turns over. So is it the Accel Coil, Thunderbolt Ignition or distributor cap? Please help. Its pissing me off! LOL
Don't check for spark using a timing light, use a spark gap tester and make sure its white or blue in color
Both are part of a system that keeps all systems with clean and stable power. Both need to be in good working order.
You didn't accidently flip a kill switch did you?
You didn't accidentally turn an electronic fuel pump of did you? My kids have done both and it baffled me for a while....
Power at the coil. + terminal. Purple wire. Should be 12vdc with ign key on run.
if you have TB IV:
if you have TB IV:
