-   -   Chargecooler plumbing (https://www.offshoreonly.com/forums/general-q/361080-chargecooler-plumbing.html)
Catchme 06-07-2019 12:40 AM
Just finishing my 525 sc build, ready for lake test soon. Have transom pickup but Wonder If I can run it thru the same seastrainer that raw water is feeding the engine from? Will there be enough water pressure om the sea strainer, or will it be sucked dry during idle causing the seawater pump to cavitate? The exit hose from chargecooler is of course locateted above waterline.....
