-   -   Manifold Restrictors Recommendations (https://www.offshoreonly.com/forums/general-q/361141-manifold-restrictors-recommendations.html)
15x 06-09-2019 10:15 PM
Some what new to the marine world... Using new Marine power exhaust manifolds, 3" spacer & riser into Corsa elbow/Tee for my side exhaust. Having low water flow out tail pipes at idle & risers getting warm compared to my old engine. Using a new Johnson pump (F6B-9) flange mounted to crank balancer. It's a closed cooling system but manifolds, risers & elbows are raw water cooled. Would a restrictor in the manifolds or spacer create more pressure or flow to help?
Crude Intentions 06-10-2019 04:22 AM
No. Sounds like a volume issue. Has it always been like this? Maybe the raw water pump you’re using isn’t adequate or you have a blockage somewhere.
