ECM 555 Locked?
I have 2003 dual Mercruiser 350 mpi withe ecm 555 controllers.i was having trouble with the starboard engine.had a mechanic check it and he said that the controller is locked and he cannot get in.The port was fine.So I purchase a vesselview mobile.I can communicate withe the port controller but the starboard controller says”error reset key”. can some help out?Can a controller be locked? |
it has no communication - it is not locked - you have either a plug / DLC issue or an internal issue of the ecm. Very easy to test to see if the issue is with the DLC so one can rule it out
Hi BUP Could you let me know how to test the ecm problem or would you rather that I phone you.Thank for helping me out. |
swap ecm's engine to engine should give idea if dlc/engine harness is ok.
Thanks, I will try that,also I will check that I have 12 volts on the outside pins of the dlc. |
Do not ever swap a good known ECM to a bad engine EVER - that is one possible way to knock out a good ecm possible making it 2 bad ecm s one has. AND THIS INFO coming form a guy who repairs ECM about an average 2 per week inwhich takes money out my hands. I bet you would never hear a competitor post such important info to help one out.
A scan tool is another way to test the ecm and of course what I am doing internal testing with a power supply, a scope, volt meter and scan tool along with sensors and injectors ,. |
Thanks for this information BUP.I read where there is a yellow wire between engines that this could cause issues,as one is a master and the other a slave ecm.I want to check to make sure the cable is okay and the voltage is 12 volts.Then I will know for sure is is the ecm. thanks alot |
BUP, how can I contact you about rebuilding my ECM?
Originally Posted by BUP
(Post 4691750)
https://cimg0.ibsrv.net/gimg/www.off...4e1041dc0b.jpg |
Originally Posted by DukeVair
(Post 4706514)
I will update the progress here when I figure out whats going on but keep in mind I DO NOT HAVE THE BOAT / ENGINES in my hand so I have to play detective first and figure out as we go. . . |
| All times are GMT -5. The time now is 10:00 PM. |
