-   -   mounting some tabs on a warlock 25sxt cat (https://www.offshoreonly.com/forums/general-q/361529-mounting-some-tabs-warlock-25sxt-cat.html)
Blowncat 509 06-29-2019 03:05 PM
wondering if anyone has ever mounted some tabs on the outer sponsons where the steps in the hull are, and would they hurt or help anything? almost like a tunnel hull jetboat or v drive would use. i need to install a seperate water pick up for my intercooler, but i dont want to have to cut acess holes in the floor to reach the bottom corners of the sponsons.. id rather mount the pickup in the cav plate/ ride plate/ tab/ whatever you call it like a v drive would. dose this sound workable? i could mount rams to the plates and make them adjustable, just not sure if the stepped area is the place to do it or not....
