-   -   Mpi stalling (https://www.offshoreonly.com/forums/general-q/361558-mpi-stalling.html)
actionmarineguy 07-01-2019 10:22 AM
Mpi stalling
6.2 mpi stalls when first started multiple times . After warm up its ok. No codes on computer . Replaced iac and filter. No change. I dont understand what iac duty cycle is reads 99.9% checked other boats the duty cycle fluctuates. Can anyone explain..thanks.
actionmarineguy 07-08-2019 08:30 AM
Can anyone help? cant figure out problem
AllDodge 07-08-2019 09:11 AM
What is the TPS voltage?
Could have a vacuum leak
Might have an issue with the ECT sensor, it might be telling the motor is warm so its getting less fuel when cold
https://cimg7.ibsrv.net/gimg/www.off...0ca1a75a19.jpg
actionmarineguy 07-08-2019 03:24 PM
thanks for advice will check. Question is ect sensor feed info only to computer. or is it the same sensor that i can read temp on laptop?
this is a twin engine boat all the readings are the same except for the duty cycle of the iac.
AllDodge 07-08-2019 05:13 PM
The reading I think should be the same as the computer is showing. To be sure I would need to get back into the wiring. If both are the same, let us know and need to dig some more
