(Another) Hardin pump issues thread...
I’ve had a ***** of a time getting this to prime. I’ve tried assembling with dish soap then marine grease instead, and new Merc impellers each time with the same result. The water is fed via a tee and garden hose right in front of the pump. I closed the valve before the sea strainer to force feed water into the engine but it still won’t pull if the valve is open and it just dumps out the drive.
When i run my finger across the machined surface and it feels like like it was polished with 80grit and it crowns in the middle. Everything is brand new.
this actually can get confusing. sounds like you have the lines on backwards?
on the mercury pumps the rotation is from the back not front
is it me or is there a crack on the lower left port in the first pic?
