-   -   Switching from RH to LH prop any issues (https://www.offshoreonly.com/forums/general-q/361877-switching-rh-lh-prop-any-issues.html)
RDY2FLY 07-18-2019 03:35 PM
I purchased a left and prop for my bravo x and I have been running a RH since new. I know that a bravo can run either direction but has anyone has issues with breaking shafts changing rotations ​​​​​​?
TxHawk 07-18-2019 04:14 PM
I believe a left hand rotation uses the weaker supported gear in the upper housing. LH drives have been known to wear out fast than a left on twin engine boats. I switched to LH, changed the cable at the shifter and run a billet cooled top cap to better support the gear set.
Good luck.
ThisIsLivin 07-19-2019 07:40 AM
+1 on the billet top cap with a good drive shower.
es99eliminator 07-19-2019 05:01 PM
+2 on the drive shower. It came with my boat when I bought it. I switched to a LH rotation as well. No issues
I read up on the forums and called mercury as well before I did it. I also am easy on my drive coming on plane.
liberator221 07-19-2019 08:41 PM
Is there a reasons or advantage to switching to left hand rotation prop? Single engine?
es99eliminator 07-20-2019 11:15 AM
RDY- I'm not a prop expert but, from what i understand and some folks i spoke with that actually use LH props say you pickup a little MPH.
Others say there boats handle a little different with the counter rotation.
In my personal experience I haven't actually swapped RH/LH, same pitch, weight, fuel etc to actually see if there was a difference. Handling wise i notice no difference.
Honestly after researching this myself and calling mercury I was looking for a RH 28P bravo. I found a used LH cheaper and bought that one.
r,
E
RDY2FLY 07-20-2019 02:17 PM
Thank for the info guys, I think I’m going to sell the LH and buy the RH to ease my mind.
ThisIsLivin 07-21-2019 04:11 PM
On a single, a LH prop offsets the engine torque and improves high speed handling.
Rookie 07-21-2019 08:08 PM
If you have the LH already just try it. If you never try it you will never know. As stated earlier, a lot of people use a left to offset the rotation of the engine at higher RPM.
