-   -   496 Mag HO running hot or is it? (https://www.offshoreonly.com/forums/general-q/361984-496-mag-ho-running-hot.html)
Steve888 07-24-2019 07:14 AM
I have a 2005 496 Mag HO and it appears to be running hot at least according to the gauge. It runs about 185-190 while traveling done the lake and goes up to around 200-205 when coming off plane and back to idle then eases back to 185-190. I looked around on line and it appears that the ECM should be going into gaurdian mode if it is truly that hot, is that correct? If that is the case then could it just be a gauge issue? This is my first boat with a closed cooling system so I am open for any information. Thanks!
AllDodge 07-24-2019 07:18 AM
Use an IR temp gun and measure the temp at thermostat housing
rak rua 07-24-2019 11:23 AM
Sounds like the gauge or sender. 160-170 is normal, 180 is high, 190 will set off an audible alarm. I've had the alarm go off and the gauge was showing around 190. Also check (I don't know how) your alarm works.
RR
Steve888 07-24-2019 02:16 PM
I went by the lake today and lowered the boat into the water and fired it up and let it idle. The temp according to the gauge was 185 but when I checked the thermostat housing with an IR temp gun the temp was 150ish depending on where the laser was pointed. I believe that the sender pictured is the gauge sender and the brass of the sender read around 148 at idle. Please double check me and make sure I am measuring the temp in the correct location. https://cimg6.ibsrv.net/gimg/www.off...7b796c398.jpeg
AllDodge 07-24-2019 06:16 PM
Agree, temp sender wire is Tan
Pull the wire and the gauge should go to cold, if grounded it goes to peg HOT
What gauges do you have Gaffey maybe?
Steve888 07-25-2019 05:09 PM
It has Livorsi gauges. I tried an Autometer sending unit on it today but the gauge read 30 degrees cooler than the IR temp gun so apparently Autometer uses a different resistance range. Does anyone know if Livorsi gauges are compatible with VDO sending units?
AllDodge 07-25-2019 05:14 PM
Unsure about auto meter, but the North American standard is 240 to 33 ohms (cold to hot or low pressure to high). There is a guy here with Gaffey gauges in his Fountain and the gauge pegs full scale max oil pressure. Replaced the sender and still pegs high. Measured the sender when cold and it measured 245 ohms, so his gauge is just bad, you may have similar issues
BUP 07-25-2019 09:31 PM
you have to match the sending unit to the gauge per ohms range.
The best way to see about the temp is to scan the engines from start up to fully warm and watch how and or the temp changes. You can compare all of that
You put the temp gun on the sensor for the reading. when testing the temps
BUP 07-25-2019 09:35 PM
and for the record many temp guns do not read all the same - I have seen 20 degree difference between brands and even 25 degree difference from older temp guns compared to new.
