Electric fuel pump died - replacement >
Old 07-25-2019 | 12:44 PM
seafordguy's Avatar
Default Electric fuel pump died - replacement
fuel pump died on my Cafe.
Amy recommended replacements? Any reason this won't work? USCG approved.....
https://www.ebay.com/itm/Holley-97-G...ty!23608!US!-1
seafordguy is offline
Old 07-25-2019 | 03:22 PM
Rookie's Avatar
97 GPH won't support too much HP. Those Holley fuel pumps have a bad rap of failing often. Holley Blue or Black would be a better choice.
I run Mallory 140's that can be fully rebuilt.
Rookie is offline
Old 07-25-2019 | 03:28 PM
What's it feeding? I used that on my 300XS without issues.
PA.WOODCHUCK is offline
Old 07-25-2019 | 08:29 PM
How many hours on the original one ? Why not replace it with the same ?
BillK is offline
Old 07-25-2019 | 11:07 PM
Carter P4601HP but you have to use a regulator.
f_inscreenname is offline
Old 07-26-2019 | 11:02 AM
seafordguy's Avatar
I assume the one that is in it now is original with the Boat so I have no idea what make/model it is.
HP is 565.
Old 07-26-2019 | 11:20 AM
14 apache's Avatar
HP is 565.
red pump will feed 800hp
14 apache is offline
Old 07-26-2019 | 03:10 PM
My red Holley pump would fall to 3psi at anything over 2000rpm rpm on 500hp. I put the stock mech pump back on and ran 7psi all day long.
Baja Rooster is offline
