-   -   Holley HP EFI install will only spin to 5150 (https://www.offshoreonly.com/forums/general-q/362081-holley-hp-efi-install-will-only-spin-5150-a.html)
Cerberus66 07-29-2019 12:02 PM
A holley hp efi was installed, limiter was set to 6300, hard limiter set to 6500 (yes very built engine) Engine will not spin past 5150.
Nordic Heat built 496 540 pro charged and make max hp at 6300.
I am thinking something left over form the old ecm or smart craft system is keeping it from moving past 5150.
Rookie 07-29-2019 08:03 PM
Did you make a prop change at the same time?
underpsi68 07-29-2019 09:18 PM
What ignition? Spark plug gap?
Tinkerer 07-29-2019 09:21 PM
do you have 8 coils or another ignition control that is wired to the single coil?
That side car ignition control could have you limited to 5150
Cerberus66 07-30-2019 12:43 PM
we found this, spark plugs are gapped to .060 should be .035, airfilter is too small and engine is collapsing it. I was told to run my LS style coils and see if i have one out. All that could lead to the problems. We run an Holley HP efi system on a LS based ignition.
Cerberus66 08-05-2019 12:57 PM
Gap pulled to .045 and BAM rpm
SB 08-05-2019 01:08 PM
Good news !
Maybe the 496/8.1L crowd will listen to me now (staying with the dumb OE spec of .060") and stop burning out their wires and coils. Someday maybe. One day closer ? LOL.
Again, great move on your part and thanks for letting us know.
Rookie 08-05-2019 09:28 PM
Originally Posted by SB (Post 4700431)
Good news !
Noted... I'm getting ready to change the plugs on my 496 2500 Avalanche.
