-   -   Fuel filter (https://www.offshoreonly.com/forums/general-q/362257-fuel-filter.html)
bstasch 08-05-2019 02:39 PM
Fuel filter
I have the s3232tul fuel filters on my TopGun. Do I have to replace with same s3232tul's or can I use the s3232 instead?
BUP 08-05-2019 04:44 PM
the S3232 TUL is UL listed and USCG approved as Racor had that end all tested and stamped. for all I/O s and inboards.
The S3232 only is NOT UL listed nor USCG approved for an I/O - inboard marine filter. Many use the this S3232 for outboards as they can buy it a tad cheaper.
IF I WAS YOU I BUY THE S3232 TUL to keep your insurance coverage just in case something happened. NOT worth the 5 to 10 bucks savings
How I know all this is because I carry these exact filters and have to install the S3232 TUL on all my customers boats because I have HUGE liability carrying a marine dealer LIC and boat sales. - Yes I have to follow many marine applied standards because of the liability. and that applies to marine dealer LIC
bstasch 08-06-2019 06:51 AM
Wow. WHo knew? I just didn't feel like changing over the glass bowl. Thank you for the information.
SB 08-06-2019 09:50 AM
Or because the TUL filter says "The TUL is listed as the replacement filter for the aluminum base/inboard/below deck approved filter" And the non YUL says "Clear Bowls: Use for outboard and above deck installations. ." :)
BUP 08-06-2019 10:56 AM
the clear see thru plastic bowls are not for I/O s or inboards but can be used for outboard engine apps. the metal bowl and the plastic bowl fit both filters. My info comes straight from racor plus I keep tabs on whats USCG approved or not, especially Starters and Alternators.
Racor had the testing done with the TUL s and METAL bowls. It is UL listed like I said. The NON TULS and plastic bowls are not UL listed.
For servicing boats I go thru about 20 to 30 per year of these exact filters the TUL . . The FST filters will mount up as well.
The Volvo DPX engines came with S 3232 TUL and so does a few handful cabin cruiser boats for a jist of info
