-   -   Any ways to increase vacuum signal? (https://www.offshoreonly.com/forums/general-q/362333-any-ways-increase-vacuum-signal.html)
SB 08-08-2019 11:46 AM
Originally Posted by SS496 (Post 4701119)
Adjust the idle mixture using the same method.....but in gear
x 2
Griff 08-08-2019 12:50 PM
With the boat tied off to the dock to simulate the load.
fbc25el 08-08-2019 01:26 PM
Originally Posted by bck (Post 4700998)
Running a Victor intake with a 1050 4500 and a 1 inch super sucker spacer on a 540. Vacuum signal at the carb is pretty weak at idle. Removing the spacer made a bit of an improvement but not enough. Maybe a 4 hole spacer might give the carb a better signal than no spacer? Any other ideas? Just trying to get the in gear idle a little better and not be overly rich to keep it running.
If your metering blocks have the idle feed restrictor " IFR " in the upper position the overlap from the cam cause a problem with the fuel flow. The IFR should be in the lower position. If you go to RACINGFUELSYSYEMS web site that pretty well explains it.
bck 08-08-2019 01:27 PM
Will attempt but idle is ****ty enough that it's tough to adjust and keep running.
bck 08-08-2019 02:06 PM
Not familiar with IFR and positions. I'll check out the link and look into it.
Tinkerer 08-08-2019 09:17 PM
Holley HP EFI - My 598 Solid roller idles in gear at 750 RPM where it wouldn't stay running for 10 seconds in gear with the carb.
articfriends 08-09-2019 02:01 PM
Do you have power valves in the carb, if you do, what # are they?
