-   -   Coil question (https://www.offshoreonly.com/forums/general-q/362393-coil-question.html)
Tombaja 08-12-2019 11:44 AM
Coil question
Guys,
New to the forum. I know these forums are a wealth of information, so I thought I'd try here first! Just bought a 98 Baja Hammer with a 7.4L (non mag)/bravo one setup. I recently had a coil failure and when I google the number on the coil (392-8055 70 1) the majority of what comes up is the number 392-8055 70A2??? Is this the same coil? For my own information, is the coil I have on my engine have an internal resistor, or external?
Thanks!!!
F-2 Speedy 08-12-2019 12:04 PM
What ignition do you have ?
Tombaja 08-12-2019 12:18 PM
That would probably be helpful to know!
I will try to get over to the storage building in the next day or so to check.
So Mercury used more than one type in that year?
F-2 Speedy 08-12-2019 12:26 PM
The part # is for a thunderbolt IV or V............ I've heard they have an internal resistor in them.
https://inboarengin.com/392-805570-1
Tombaja 08-12-2019 12:34 PM
If I am reading things correctly, the difference between the IV & V is the V's ability to advance/retard the ignition timing based on a knock sensor?
Tombaja 08-12-2019 12:51 PM
I was thinking about getting something with a bit hotter spark like the Pertronix 40511, but was unsure of the resistance required.
SB 08-12-2019 01:06 PM
The TBIV and V ignitions (most carb engines) use a coil that , if I remember correctly, has .6ohm resistance. If you use a coil with different resistance you run a chance at frying the Thunderbolt timing module/amplifier. The OE coil does not use a resistor to step down the voltage. Just the old points type did.
98% of the computer controlled Merc engines used the ACDelco EST coil. Only a few used the Thunderbolt style. These will fire a SC engine with 7pounds boost and 5k+ rpms. It. also, is plenty fine for most marine engines that use this style coil.
The Thunderbolt V differentiates itself from the IV by using a knock sensor and a timing strategy (Mean Best Timing) in the module, vs a fixed 'curve' in the IV's module. Yes, a few V's did not use a knock sensor.
Tombaja 08-12-2019 01:16 PM
Interesting...
Pertronix does sell a .6 ohm coil.
I was initially concerned about the engines poor starting (it just kind of started by catching on a couple of cylinders then everything would start firing) but after my wife caught glimpse of the giant spark arching across the high output and the primary negative, I knew what part of the problem was. Of course not before I had to do the float of shame from the dock to the trailer because it decided it had had enough. :picard1:
F-2 Speedy 08-12-2019 02:10 PM
Put the OE coil on it, their cheap and dont put anything on it that says MSD ( may start deteriorating )
BUP 08-12-2019 09:07 PM
you have to use a coil that matches the primary and secondary resistance of the OEM coil no matter if it is T bolt IV or V or the est set up. The big block Merc s Black side 454 / 502 used a est ignition set up not the same T bolt set ups.. There is couple of sources to buy the exact coil or even better but its very few sources -- Sierra is NOT one of those sources. . Way to many poor quality copies from secondary China makers.
The EST coil is a NON oil filled coil. Pertronix does not have the coil your looking for unless they added it to their line up but I doubt it.
Many Merc efi engines used the T bolt set up as well. The small blocks including many 6.2 and the 4.3
BUP 08-12-2019 09:15 PM
6.2 EFI as mentioned used T bolt ignition on many Merc engines. And for the record the OIL filled coil is not oil filled anymore. I have had issues with the current coil. I went back to an oil filled coil that I sourced out and have not looked back. This also includes the HP 500 carb engine T bolt ignition coil... Giving the heads up about this one..
MerCruiser MX 6.2L MPI Bravo Distributor & Ignition Components Parts
BUP 08-12-2019 09:40 PM
Adding some info --- Thunder bolt 4 did not use any knock sensors nor did it have the added ICM
. T bolt V used the added ICM. Also It had knock sensors --- even for carb engines, the T bolt V -- 5.7 350 CID had a knock sensor . T bolt V had MBT and ASA and ISSC and REV limiter -- some called it Over Speed control as well..
. T bolt 4 was in carb engines and T bolt V was in both carb and EFI engines.
Bondo 08-13-2019 04:31 AM
Originally Posted by Tombaja (Post 4701682)
Interesting...
Ayuh,..... Electricity is lazy, 'n follows the path of least resistance,.....
There's a good chance ya need a coil wire, or cap, 'n rotor, or plug wires, or spark plugs, as there's extra resistance down stream of the coil which caused the problem in the 1st place,....
You'll also need the new coil, as once it does what it's doin', it'll continue after you fix the initial problem,....
Tombaja 08-13-2019 06:30 AM
Thanks guys. I took F-2 Speedy's advice and bought a OE unit. I will probably go ahead and replace cap, rotor and wires also.
Donzi1979 08-13-2019 01:35 PM
BUP,
What is wrong with the new style coil? I just bought a new OE 300-8M0079202 one to replace the 20 year old on my HP500, now I'm questioning that decision.
BUP 08-13-2019 08:19 PM
Shake the coil and see if you have the oil in it ? they went to an epoxy fill no more oil. engine miss fires after it gets hot. Keep in mind I quit buying them since last year and went to a sourced out oil filled coil. The quality oil filled coils lasted a long time. You have that proof as well 20 years correct . Only mount oil filled coils perfectly vertical
BUP 08-13-2019 08:21 PM
Test it and see --- Who knows you might have a good one or the issues were taken care of by now with the coils. I do not care I went and sourced my own instead of the average quality China sourced ones. The box will say China on it correct ??
With all that said even a broken clock WORKS GREAT TWICE A DAY.
SB 08-13-2019 11:52 PM
Andover Coils by any chance ?
edit in: according to their Facebook page they went out of business several years ago and building torndown. Supposedly bought by Engineered Performance Ignition Co. but I see nothing on that. Bummer. Andover was where a lot of the good coils came from.
