-   -   forged piston OIL consumption (https://www.offshoreonly.com/forums/general-q/36253-forged-piston-oil-consumption.html)
dean campbell 11-04-2002 02:41 PM
Originally posted by rjcardinal
One thing to remember is that the 502 will use more oil than the 7.4 because it has forged pistons. The cast pistons in the 7.4 dont expand as much as the forged pistons of the 502 do. Because of this the piston clearances on a 7.4 is smaller because you dont have to leave room for expansion.
If you think you are having a lean condition with the reprogrammed ecu borrow a stock one and run it. The stock ecu is fairly rich and should be good enough to give you a baseline.
Good luck and post what you find.
Ron
how much oil consumption is acceptable for forged pistons though, isn’t a quart/hour a little excessive, or is that pretty normal?
you guys with forged pistons what kind of oil/hr usage are you seeing?
hopefully, i will have forged pistons by spring, so just looking for what i should be expecting come boat’n time.
formula31 11-04-2002 03:48 PM
I run TRW forged (454 +.030)and my clearances are a little tighter than most recommend (.003-.0035). According to my machine shop, the TRW's dont swell as much as other forged. Ive never hurt one but I dont ask for more than 450hp or so at 5400. I file fit my rings to .021 gap and I dont burn any oil at all.
bobl 11-04-2002 07:19 PM
I would not expect to see a lot of oil consumption if an engine is built properly with forged pistons. The GM 502's use a low tension oil ring which tends to allow a little more oil by. I usually use a standard tension oil ring and haven't had any oil consumption problems. My personal 555/600hp engine uses at the most a quart in 30 hrs.
Kanookstr 11-04-2002 07:41 PM
bobl is correct. It's not because they are forged pistons. the 502 Actually use metric rings and thats why they use more oil. on the average it's about 1 quart every 10 hrs, but that can change depending how hard you run.;)
Griff 11-05-2002 12:29 AM
My 1993 454 mag with 450+ hrs uses a quart every 10-12 hrs.
My 1996 525SC with 265 hrs only uses a quart about every 20-25 hrs.
ursus 11-05-2002 08:20 AM
about a quart in the 1st 5 hours during breakin,,
now basically I use a totl of about 1/2 - 3/4 of a one quart bottle to top it up between 25 hour oil changes. They can be built to use oil or not depending on rings/clearances,,my builder reco'ed not unless you were 500++hp and said it was more common to do drag engines that way, less friction=more hp and they don't care about consumption on the<10sec runs
Dave M 11-05-2002 11:39 AM
1997 454 Mag. I use about a quart every 10-15 hours.
baja bailey 11-05-2002 01:44 PM
1999 502 mag mpi. Not running hard can go 10-15 hrs before using a quart. Run it wide open a couple of times(only for about 45 seconds each time) will usually drop half quart in that one day...
