Link bar lifters and valley pan 525efi
How are you guys modifying 525efi block valley pan to run link bar Johnson lifters? Dont want to put it all back together and have them hit...
Originally Posted by 382fastechh
(Post 4703520)
I read running without it can cause oil consumption due to the PVC valve being directly above the tray?
If you're running the stock lower plenum I would not remove it, as you read its an issue with the PCV location
(Post 4703600)
You guys make it sound like relocating the pcv is an act of god...plug the old one and throw it in one of the heads. Done. We’ve been running it fine for 3 years. |
Call bill at ateco he has modified valley pans on the shelf . |
| All times are GMT -5. The time now is 03:33 AM. |
