1989 Yamaha 175hp
asking for a friend (seriously). 1989 Yamaha 175 hp precision blend V6 oil injection problem: the 3 cylinders on the port side are not firing. The coil packs are good (swapped with known good from starboard side). Wires from terminal block to coil pack all ohm out good No obvious broken wires what next? Any feedback Greatly appreciated. |
Check fuses. |
Go to CDI Electronics web site and download there troubleshooting guild. You will need a peak reading voltmeter or adapter to test outputs.
Thanks. I found that cdi site with the troubleshooting pdf. Very informative. |
| All times are GMT -5. The time now is 11:53 AM. |
