Originally Posted by scippy
(Post 4703994)
So my engines are 9 :1 comp. & if there tuned to 89 octane what damage would occur by continuing to use AV gas?.......burnt exhaust valve?......using it was a decision simply for it's shelf life.
I still have 50 gals left from it's initial fill up ...boat has only been used 5 hours since buying it........maybe a dumb reason to have used AV gas in the first place, but I'm sure auto gas would have turned to varnish by now!........If it's too complicated to tune for AV gas with AS&M EFI's (not sure about ECM).....Thought the remedy would be pulse widths for injectors to compensate for AV then auto gas would be less complicated! The only way to adjust the BPW is by tuning. If you are tuned for 89, and run AV gas it will be 'rich'. If it is tuned for AV gas and you run 89, it will run lean. If you are concerned I'd just mix your remaining AV gas with 89/91 till its gone. |
Trash I believe it's the opposite ...9:1 and tuned for 89 octane motors are running very lean with AV..........your suggestion is best advice fill w/91 and run. Can't answer about ECM I'm not sure.
articfriends yes shelf life concern & to do all this end around like zz28zz said, sad story in the end! |
(Post 4704067)
Jesus, just use the 50 gallons in a mower of something . why in the world would you change your entire tune and take a chance of ****ing up 2 engines over 50 gallons in gas?!
Pretty blunt, but great advice!
Another thought too, most tunes are NOT not very edge of burndown by any means, ie, if I tune a NA motor at 12.2 afr, guy changes fuel and it runs 12.5 its not going to just melt a piston. Theres always some margin in most tunes, I think your putting way too much thought into this, Smitty
Originally Posted by articfriends
(Post 4704263)
| All times are GMT -5. The time now is 08:20 PM. |
