-   -   Mercury racing 525efi power steering pump (https://www.offshoreonly.com/forums/general-q/362670-mercury-racing-525efi-power-steering-pump.html)
fastlane40 08-28-2019 05:45 AM
Can anybody tell me anything about the pressure valve mounted on the pump?
JBmarine 08-28-2019 08:37 AM
Assuming your talking about the "check valve" screwed to back of pump (that the ps hose attaches to)...it is a one-way valve that (in twin eng applications) prevents overflowing non-running eng's reservior...primarily when, only, one eng is running.
Hope that helps!?!...Jason
@InshoreOff
fastlane40 08-28-2019 04:44 PM
Thanks for the reply Jason.
Is that valve able to be screwed out?
If it’s not there can it affect the operation of the pump?
I fitted 525’s into a older boat and have no power assist.
I believe everything is connected right.Still have cable from helm and it is fine.
Seems like the pump is not pumping??
F-2 Speedy 08-28-2019 04:51 PM
Did you bleed the air out of the system, are you running a cooler
fastlane40 08-28-2019 04:55 PM
Yes ran it for a long time.
Should be self bleeding by wheel turns?
Has a cooler.
F-2 Speedy 08-28-2019 05:42 PM
If there is any foaming in the fluid it still has air in the system, I remove the serpentine belt and spin the pump with a drill while turning the wheel lock to lock.......you sure the lines arent switched
JBmarine 08-28-2019 08:00 PM
The easiest way to verify pump operation is by testing output pressure with gauge set.
If you have one or more external add-on cylinders, you may want to disconnect hoses and make sure seals are not holding the rams tight from freely moving.
Since your setup is cable with power assist...I would disconnect cable from drive, and remove from the actuator. Make sure tube (that cable slides thru) is cleaned, greased, and cable slides thru freely. While cable is out make sure at helm wheel turns with ease.
If cable moves free, the actuator tube is internally clean-greased, and the pressure is good from pump...then issue is the actuator itself.
Jason
@InshoreOff
fastlane40 08-28-2019 09:46 PM
There seems to be no turbulence in the pump reservoir.
i have checked the cable and it is free.
Need to check output pressure next.
Saginaw rack,high pressure line is on left looking at transom?
fastlane40 08-31-2019 11:34 PM
Put a gauge on the pump outlet and nothing.
No resistance at all when turned by hand.
Can only be the pump??
fastlane40 09-02-2019 05:48 AM
Pulled the pump from one of the race motors and straight away power steering.
It is very jerky and ratchety.How long should it take to get all the air out of the system.
Ran it at idle turning wheel back and forth for 3 minutes.
F2 Speedy thanks for your help.
F-2 Speedy 09-02-2019 09:26 AM
Are you running full hydro steering ? ITS ?.......... Im running the Cadi pump and the valve looked the same when changing it out.
fastlane40 09-02-2019 01:59 PM
This is a rebuild and am yet to fit external hydraulic.
I do have it all to fit.
Is the valve internal in the pump?
F-2 Speedy 09-02-2019 02:39 PM
unscrew the the the large nut where the high pressure line hooks up it site behind there
fastlane40 09-03-2019 05:26 AM
What do you think about the jumpy ratchety feeling in the steering now,Air??
It feels like air but I would think it should have bled itself by now.
Thanks too,you've been a great help.
fastlane40 09-03-2019 05:29 AM
Just reread one of your posts.
I wouldn't have power assist if the lines were crossed?
Wonder if the rack failing gives similar symptoms.
F-2 Speedy 09-04-2019 10:33 AM
Im not sure , Ive not done power assist, can you post pics ?
