350 Magnum, no spark on new motor >
Like Tree8Likes
Old 09-08-2019, 02:24 PM
Thanks again to you guys that helped me with my issue. I replaced the pick-up in the distributor today and the engine almost started itself!
Ron
Metro man is offline
Old 09-12-2019, 10:46 PM
BUP
So my post help you get the engine running - It should have been a T bolt V ignition set up and that is called an ignition sensor assembly. under the rotor as you changed that out --- correct ?.
The est ignition set up has the pick up coil and the distributor has to be removed to change that out.- you should not have that set up period from an OEM stock mercruiser app.
BUP is offline
Old 09-16-2019, 06:01 AM
Ron
OSO Sponsor
OSO Advertiser
OSO Advertiser
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
OSO Advertiser
