Can you pull 502 BBC crank w/o removing heads >
Old 09-15-2019, 12:51 PM
Will do BUP. Hopefully just bearing fines.
Cap'm Kurt is offline
Old 09-15-2019, 12:58 PM
I will take ya'lls advice and strip it if signs of shavings anywhere other than pan and the oil filter since it only ran a few seconds when knocking. Of course it might have been tearing up one journal bearing for awhile before that just didn't start knocking untill restarted it.
thanks. I will give update.
Old 09-16-2019, 06:55 AM
flashgordon's Avatar
yea , as stated already , if you have metal in oil, you need to completely go thru motor.
i just had to do this , as a result of destroying a valley baffle.
oil filter caught 99 % of metal,,,,thanks WIX.
but tanked the block , all new bearings rings, washed soaked lifters real good,
then put it all together.
flashgordon is offline
Old 10-05-2019, 11:36 AM
Originally Posted by AllDodge View Post
This takes me back to my 20's when I didn't have much money and did an in-block overhaul in my drive way. Pulled heads but not the block. When installing the crank, under the car it was a bit windy. Didn't plastic gauge and think some dust got on the bearings. I didn't get 50 miles out of the motor before the rods started knocking
That is a great story. Though depending on bearings, a certain amount of 'bedding' in the bearing babbit saves a lot of potential failures. I had some thrust on my crank that ate away the thrust bearing, and put it into the oil. Oil bypass, was feeding the large chunks to the mains. Took an all day WOT to end up spinning a bearing on #4 SBC 355.
On teardown, I could not believe how much foreign material was bedded into the bearing, and still functioning.
That is one factor of the oil suction dipstick style, the oil in the trap does not move, and does not represent the actual state of the engine oil. So when I check oil every daily use, I only saw clean oil. Blowing the tube out, will fix that though.
Tartilla is offline
Old 10-05-2019, 03:49 PM
If your at the point of pulling and opening the bottom end how much more would full refresh cost? I hate going over budget but the piece of mind knowing it’s good for another grand.
Powerquest230 is offline
Old 10-05-2019, 04:02 PM
Absolutely you can do this. I've done it many times.
thirdchildhood is offline
OSO Sponsor
OSO Advertiser
OSO Advertiser
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information
Copyright © 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
OSO Advertiser
