Hydraulic steering cylinder stop
Hey all, I am doing a full hydraulic steering install this winter and have a question regarding the cylinders. Is it necessary to install internal cylinder stops? I know the power steering pump should relieve around 1500 psi. If the cylinder extends to the point that the drive limits its travel and activates the pressure relief valve will it damage the drive? Or will the pressure relief valve prevent damage to the drive? Thanks in advance! |
The rams should be mounted so that when one is fully extended, then the other is fully retracted.
The drive can turn farther than any rams that I've seen will allow. |
Thanks Griff, So I am assuming that in a single ram setup the ram is the limit not the drive travel?
Originally Posted by iaff284
(Post 4712853)
If the drive stops the rams before the rams bottom out it will break something before the relief valve opens.
There was a guy on here that hooked the hoses up wrong and both rams extended when he fired the engine and it broke the gimbal ring. |
Originally Posted by Tinkerer
(Post 4712949)
| All times are GMT -5. The time now is 03:33 PM. |
