-   -   Cam choice (https://www.offshoreonly.com/forums/general-q/363750-cam-choice.html)
jdf4068 11-05-2019 03:03 PM
Cam choice
thinking abt a cam change what is in there now is comp cam extreme marine 284 hr... spec 230/236. 547/547 lift ..... motor spec. Are stroked 454 to a 496...9.5 to 1 comp ..heads are alum 330 runners. With 2.250/1.99 valves What would y’all recommend
GPM 11-05-2019 03:09 PM
Oh, you opened the can now,
jdf4068 11-05-2019 03:18 PM
lmao. I’m bored we need some drama. ..
sutphen 30 11-05-2019 03:40 PM
3/4 race cam for sure.:D
cigrocket 11-05-2019 03:43 PM
Ways to start Drama on offshore only..... Cams, Oil, Apache, Tow Vehicle rating. It is only November......lol
BBYSTWY 11-05-2019 04:35 PM
278/288
228/238 at .050
.612/.618 lift
114 lobe separation
With a set of tie bar comp lifters....if only you could find one....
I know exactly where one is right now lol
jdf4068 11-05-2019 04:56 PM
Originally Posted by BBYSTWY (Post 4713764)
278/288
228/238 at .050
.612/.618 lift
114 lobe separation
you do ,,looks like a nice cam ....who made it
jdf4068 11-05-2019 04:57 PM
lol.
BBYSTWY 11-05-2019 05:01 PM
Comp custom grind...ran it in my motor for 8-9 hours...nothing wrong with it at all just going a little bigger
Its a flat/button nose cam
If you're interested PM me...was gonna throw it on here once I get it pulled which should be this coming Saturday.
GPM 11-05-2019 05:11 PM
What are your plans for the boat, how are you going to run it, towing skiers, cruising or a lot of wot ? what exhaust , what intake, carb or efi ?
phragle 11-05-2019 05:15 PM
Custom Bob Straub 7/8 race grind with the even/odd cylinder swap with 3.14159265359 degree advance.
jdf4068 11-05-2019 05:43 PM
to answer your question,,,cruiser 89 scarab 3. Has dual plane now ..going single for sure,,,exhuast is gill offshore wet style ..ard 5500- 5800,,, props are hydro 4 blade 27 pitch ...bravo drive 1.50 Does this help ?
jdf4068 11-05-2019 05:44 PM
i might be. Then i could have another made ,,,
phragle 11-05-2019 05:45 PM
Belt driven intake manifolds would really wake it up.....
jdf4068 11-05-2019 05:45 PM
naw dawg. Let’s go full race deal ,,lol
GPM 11-05-2019 05:50 PM
Did you do any port work on the heads
compedgemarine 11-05-2019 06:08 PM
had an old timer at a car show once ask me if I had a 3/4 cam in my motor, I said "no, I put the whole thing in there". he didnt seem impressed with my answer.
jdf4068 11-05-2019 06:21 PM
no not really just cleaned up a few spots ...123 cc
GPM 11-05-2019 06:59 PM
What compression ratio
jdf4068 11-05-2019 07:09 PM
9.5
GPM 11-05-2019 07:26 PM
Not sure the difference between solid flat tappet and what you're going to run but a Bullet 246 /254 made 540 HP 520 torque in a 468 at 6200. The 496 stroker would probably make more and top out at 5800.
GPM 11-05-2019 07:28 PM
I'm sure Bullet could make you a nice cam, techs seem to be decent.
Baja Rooster 11-05-2019 08:39 PM
22 post and no Bob M reference? Slackin’!
I’d look at the Airgap dual plane intake. It seems to outperform any single plane until you get over about 555cu plus.
jdf4068 11-05-2019 08:55 PM
22 post and no Bob M reference? Slackin’! Lmao. What ever happen too him ....
phragle 11-05-2019 09:36 PM
No slackers here....read a little closer.....
Full Force 11-06-2019 04:57 AM
Flow the heads if you want to pick the best cam, if not you are guessing what you need....
flashgordon 11-06-2019 06:24 AM
yea for sure A 3/4 RACE CAM
love hearing that from people ,,showed what they knew in 3 words....hahahah
i would go with a FULL race cam
my cam roller solid red zone lifters
http://iskycams.com/shop/index.php?m...roducts_id=702
head are 14044861 bow tie heads flowed by carl foltzhttp://www.cferacing.com/
1050 carb..
so far highest i pused motors was 5600
Full Force 11-06-2019 04:17 PM
jdf4068 11-06-2019 06:02 PM
Originally Posted by Full Force (Post 4713931)
now thats funny ,,,i dont care who you are ,,,loll
hogie roll 11-06-2019 06:54 PM
Not bad, could use more lift though.
sutphen 30 11-07-2019 06:04 AM
what do you mean by this?
flashgordon 11-07-2019 06:08 AM
people that tell you they are running a 3/4 race cam ................ are idiots.
flashgordon 11-07-2019 06:10 AM
this comment was for which post??
my cams are 720 lift at rocker.
TylerBurich 11-07-2019 07:47 AM
Fellow boater has that same cam in a Coretti 525hp 496 in his formula. Bullet specd the same duration for another Formula on our home lake with 496's. Seems like a popular choice for mild builds, needs more lift in my opinion though.
hogie roll 11-07-2019 10:17 AM
The OP
TomZ 11-08-2019 06:53 AM
And here’s an article giving the history of the 3/4 race cam... for anyone interested:
https://www.enginelabs.com/engine-te...race-camshaft/
phragle 11-08-2019 11:28 AM
If your worried about reversion with a 3/4 race cam, use an RV cam...
thirdchildhood 11-08-2019 12:37 PM
My 1982 Mustang GT was advertised by Ford as having a marine grind cam and made a whopping 157 hp. Now it makes about 450, lol.
