Bravo fresh water pump
Normally the pump is mounted on the left side of the block I have a 31 American offshore changing my motors and rigging using bravo pumps with mechanical fuel pumps can you mount the pump on the right side of the block |
The 3 that I have had were mounted on the RH side of the block. (Starboard side) |
Same here. Raw water pump and mech fuel pump are on the same side of both engs (right/starboard side). Raw water pump is down low.
Ok cool just checking cause most are on the left of facing the motor |
Originally Posted by mbasile1982
(Post 4714448)
Correct I’m asking if you can mount them on the right side of the motor in a cat the port motor there’s more room on the right side |
(Post 4714459)
Yea I would do that but I want to do mechanical fuel pumps I know I’m a pain in ass lol |
I see no reason that you can't put it on the other side, but you would probably need to have a custom bracket made.
I didn’t think it would be just didn’t know if anyone did it before |
| All times are GMT -5. The time now is 12:02 PM. |
