Can help
I’m refreshing a 1995 502 efi mag it needs a cam as it was starting to eat a lobe im up grading the flat tappet for a hydraulic roller and may go roller rockers as well without getting the factory Merc eci re programmed I would like a cam recommendation boat has the factory captains call exhaust and manifolds don’t want to change the exhaust either any help or suggestions appreciated |
288*/288* seat
224*/224* @.050" .483"/.483" valve 115.5* LSA 109* ICL 122* ECL |
Originally Posted by phragle
(Post 4714468)
288*/288* seat
Originally Posted by Griff
(Post 4714485)
Which is the stock roller cam in the Gen VI 454/502MPI's
Well he doesnt want to tune or change the exhaust.... |
I'm pulling mine next month to install a more aggressive cam so I could supply:
Cam - roller stock 200 hrs, springs from same, Rockers Comp Extreme new (less than an hour), Let me know if any of this works for you. |
Can you give me some specs on the cam? |
If you go with roller rockers, highly recommended, I have a set of new Comp Cam extreme for sale $ 300 ROLLER TAPPET CAMSHAFTENGINE MODEL 7.4L 454 MAGNUM 502 MAGNUM 8.2L Lobe Lift + .020 (0.051) Exhaust .284 (7.214) .342 (8.687) Intake .282 (7.163) .342 (8.687) Duration at .050 In. (1.27 mm) Cam Lift Exhaust 209° 227° Intake 209° 211° Journal Diameter 1.94282-1.9492 (49.485-49.509) Journal Out Of Round .001 (0.025) Maximum Camshaft Runout .002 (0.051) Maximum Timing Chain Deflection .375 (9.5) from taut position [total .75 (19)] |
I’m interested in the rockers and cam i need to talk to my builder, I’m out of town for the next week and a half and won’t see him until late next week what valve cover did you use with the rockers? and how much for the cam |
(Post 4714494)
Thanks griff i |
Hi all another question about this motor 1995 502 mercrusier 415 hp are the pistons flat top or do they have a small dome with valve relief |
this site may be of use to you.
https://www.perfprotech.com/blog/tec...specifications |
Thank you |
Hi Glenany 242 SS your number was on one of the messages and now I don’t see it or I would call can you call me at 412 956 7182 thanks |
| All times are GMT -5. The time now is 11:13 AM. |
