Hardin cyclones
Did some reading and not much input either way especially recently. Is anyone using these or has used these? I currently have Gils and want easier plug access. And maybe something shiny. Just looking for feedback. Mike |
Salt water or fresh water? Engine application? PM me all the questions you have as I am very familiar with the Cyclone shorty headers.
I too am wondering about these. Do they help or hurt hp and torque?
I have a set I got used. i havent ran them yet but they look very nicely built. One had a pinhole leak and I repaired it. Pressure tested both with 150psi and it held over night so I called them good. I am really looking forward to running them though.
Originally Posted by LS1
(Post 4715002)
Originally Posted by bigboat28
(Post 4715011)
im already running gils. Can’t see these being worse than gils. Quality and longevity are my concerns. |
Originally Posted by Redneckcustoms13
(Post 4715041)
(Post 4715041)
I think a lot of the issues must be we not flushing with a LOT of volume of water and using salt away/ dawn, granted my E-Tops and not full length runners but they are still in good shape with 7 years of salt running at 20 years total. Not pushing my luck will replace them after the new years run. |
Ran these on my 565's. Good alternative to the gils with no tailpipe modifications. I was very pleased with the quality.
Originally Posted by KWright
(Post 4715147)
(Post 4715147)
(Post 4715184)
Any power loss?
I had the Gil cast aluminum manifolds that leaked and became impossible to wield went with the cyclones and could not be happier https://cimg8.ibsrv.net/gimg/www.off...b19d4c245b.jpg
Never ran them In comparison with the gils. They were an upgrade when I built my 565's. I knew i wasn't keeping my 35, so I didn't want to spend a ton on complete new exhaust. We made good power with them over 750. I would use them again if I didn't want to do completely new.
Originally Posted by green lightning
(Post 4715207)
I have been eyeing these also. What do you think will be the most reliable in the long run cyclone, cmi fusion or eddie marine manifolds?
Originally Posted by lush
(Post 4715210)
if you already have gils these seem like the best bet. You don’t need new risers/tails. |
Originally Posted by Crude Intentions
(Post 4715209)
how long have you had them? I’m really thinking this is the route I will go. Don’t wanna drop a fortune on all new stuff. My tails are already fairly new. |
I just removed the stock manifolds and did away with the quick and quite.
(Post 4715216)
I bought them in 2009 for use in the 2010 boating season
(Post 4715207)
my question is where do you get green serp. belts?
Originally Posted by SABER28
(Post 4715330)
Gates HD belts have green backing
Mine are 2012. The leak was at the internal brazed joint under where the gil tail bolts. It was absolutely due to them not being flushed well. Came off a salt water boat. I got them for a fair price and once I spoke with hardin about how they could possibly have welded that they told me that part is not welded. It is brazed. Easy enough. I sand blasted it and cleaned it well. Then brazed with a ssf-6 rod. Put 2 plugs in he lower outlets and a valve stem on a plug in the top. Shot it up to 150 psi of shop air. Sat it in a tub of soapy water and watched for about 5 mins. No bubbles. Next day before I removed the plugs, I read the pressure and it was still right at 149-150.
Has anyone run these in a bigger(540 650 hp ish) NA setup? I have gils and was considering buying a pair of E tops but if these will do just as well(or really close) I can save quite a bit of money.
Originally Posted by farmo83
(Post 4715366)
(Post 4715330)
https://cimg4.ibsrv.net/gimg/www.off...2a98d133ea.jpg
(Post 4715366)
Originally Posted by Baja Rooster
(Post 4715318)
There’s a lot of pretty in that engine bay. |
(Post 4715374)
Looking at them it doesn't look like the runner on E-Tops are all that much longer. If you want I can measure mine E-Top runners. I just happen to have one off.
(Post 4715390)
(Post 4715398)
They look good but do they help or hurt power?
I would think these would hold up well against e tops, and pretty much any manifold except the old Kieth Eichert's. Against a Sport Tube or some other long runner header I think they would start restricting power???
(Post 4715390)
(Post 4715413)
(Post 4715418)
Are those 02 sensor plate something you had machined or is that available from a vendor? How do they affect the fitment at the transom?
https://cimg7.ibsrv.net/gimg/www.off...51026e6d01.jpg
(Post 4715398)
| All times are GMT -5. The time now is 09:12 AM. |
