-   -   Webster stud girdles with Keith Eckerd 2pc valve covers (https://www.offshoreonly.com/forums/general-q/365166-webster-stud-girdles-keith-eckerd-2pc-valve-covers.html)
Nbn 02-29-2020 09:23 AM
Can I make the Keith Eckard two piece valve covers work with Webster stud girdles and have enough clearance with the three-quarter or 1 inch valve cover spacers does anybody have any experience with it? Motors are
world block low decks and world heads
cmi etop exhaust with roller rockers
looking to add space for Webster girdle
doable ?
sutphen 30 03-01-2020 11:12 AM
what cam do you have,,most likely girdle will not fit.will need a space w/ the KE spacer.
Nbn 03-01-2020 03:55 PM
Not sure what cam is used, but the motors are
555ci blown with 875hp dyno
they just tried fitting the girdle for valve cover clearance
Instead the Webster’s designed shape extends
to far in the way of the quick release wing bolts
looking at the pictures of the Howard cams girdle any one know if they could clear
wing bolts and spaced up to fit? 3/4 to 1 inch
maybe?
Nbn 03-07-2020 10:56 PM
Could not space the KE valve covers up to fit
girdles ,headers Interfered with the 2 piece covers
went with the Teague Marine angle cut covers
to be able to top off my Mechanical roller valve train with peace of mind having the Webster girdles, Holding it together
2 sets of 2 piece valve covers will be going up for sale !
tmmii 03-07-2020 11:30 PM
with oilers or without? Price? I’m piecing together my next winter builds lol.
Nbn 03-08-2020 09:19 PM
Oilers. No
2 complete sets with breathers $375
tmmii 03-09-2020 07:03 AM
Originally Posted by Nbn (Post 4728600)
Oilers. No
consider them sold. Sending pm now.
flashgordon 03-09-2020 10:26 AM
why are you going to a stud girdle???
added strength in rocker system, i would guess.
i almost wish i had set up on my motors. get tired of adjusting rockers.
but , my engine builder doesn't like them , said dont need running only 5500--5700 rpm.
F-2 Speedy 03-09-2020 10:45 AM
the more aggressive the valve train and spring pressures it will flex the rocker studs, that's why some go to shaft rockers, I run the websters also, good choice
flashgordon 03-09-2020 11:16 AM
what are webster???
rock shaft system?
or its a stud girdle system....
i had jomars on my super gas car...
again i was going to put stud girdle on my motors, and engine builder said , i dont need and stud girdle are tuff on aluminum heads
my isky cams are 714 lift,,,dont know spring pressure.
F-2 Speedy 03-09-2020 11:49 AM
Originally Posted by flashgordon (Post 4728640)
what are webster???
rock shaft system?
I don't even understand this statement...@ that lift your running a solid roller ? is the reason for valve adjustment.....Webster is the manufacturer in Cali....not to hijack the OP's thread
flashgordon 03-09-2020 11:49 AM
doable ?
wondering same thing as you ,,what would fit under valve covers , then must be able to get covers off.
we have same exhaust i think.
maybe time to look at stud girdle ......
jomar is another brand,,ran jomar setup before on super gas car.
flashgordon 03-09-2020 05:17 PM
ahhhh,,,yea i am running isky red zone solid rollers,,,,isky cam is 714 lift
so,,,,??????
yes sorry to hijack OP thread also...
