hp estimation-help needed
just wondering :
540 cu.in with dart heads + 10 lbs boost on top of it with optimum cam and carbs. how many hp it has to generate?!? can it produce around 850hp? |
YES!
yaaa
Why not try 14 lbs you should hit the 850 mark for a couple minutes:D :D :D :D :D
The 540 with 1.1HP/CID gets you 600HP and then add 9lbs/18=50% increase gets you to 900HP.
Should be easy,My Troy Dennis small blocks with 9lbs dynoed at 785hp.
Hey Timicun,
What kind of cam and what compression ratio are you running ? If I can broom my boat this spring I will start on another 540 for whatever new boat I end up with. I plan on supercharging and also want to make around 850hp. |
Thats a lot of boost man.
With 6#s out of our 10-71s on top of 8.03:1 CR. 557s...we got 850. How much CR you think your going to end up with? |
Too much boost for pump gas.
planning to build engines : just an idea for the moment. dont have the chargers or cam but perhaps will be around:
comp. around 8:1 cam around: @.050....240 , 632 lifts in/ex. superchiller msd boost retarder box for safety our octane around :90 ( dunno if there are different standarts for this.but our gas is not very cool) what boost would you use with pump gas ? |
Your like 13.5 to 1 CR with those numbers. Alltitude can change this but that is way to much CR for pump gas. I think I would build as big a cubic inch motor you can and then keep the boost low. Thats how engine builders make the big HP numbers and advertize running on 87 octane. What everyou do I would invest in some pyrometer gauges and knock sensors. Might save you some broken parts down the road. 850hp from a 540 does not need that much boost as the other posts have stated. As long as you have a set of good flowing heads.
Back4more what heads are you running? |
| All times are GMT -5. The time now is 04:47 AM. |
