496 mag ho dts to manual
So trying to sort out what’s more economical. The engine is set up with digital(electric ) throttle
boat is rigged with manual throttle and shift cables. probably not as easy as just pull electric off and bolting on a manual Arm and bracket. That’s to easy. has graffig controls shift lever and throttle lever. |
if the engine is DTS then the PCM 555 is calibrated for that as well. That PCM will not work for a mechanical throttle and shift but it can be recalibrated or new one bought per that app set up. . Also the throttle body itself is not the same not even close plus its actually has a 5 mm bigger bore opening or maybe 10mm - its one of those - I forgot . Also there is NO IAC with a DTS engine nor an IAC muffler. All Merc 555 controlled engines with mechanical T/S need an IAC. Also there is bit more but his is the main jist of it. If new parts installed and labor you are easily looking at 5 K min for the complete install.
If you need more info I can help when needed for that end, have worked on both applications and very in the know of all these marine ECM s & PCMs and their calibrations. Wanted to make sure you knew about the PCM and the calibrations are not the same for a plug play switching over to NON DTS. |
| All times are GMT -5. The time now is 11:35 AM. |
