-   -   502mag EFI distributor problem (https://www.offshoreonly.com/forums/general-q/365634-502mag-efi-distributor-problem.html)
ksalmine 04-02-2020 09:23 AM
I'm building gen V 502mag EFI for more power and change mefi to holley terminator X. Also change distributor to Holley dual sync so I can make sequential injection mode. Hope that help idle quality with bigger roller cam.
Problem is that HEI style cap is so high that it will not fit under upper intake. Does any manufacturer make lower profile cap where spark wire connectors are pointed sideways?
Another option is machine spacer plates below upper intake, but it's not good choice because I already modify lower intake ports.
Lowering the distributor is quite complicated.
https://cimg0.ibsrv.net/gimg/www.off...03689b748e.jpg
https://cimg5.ibsrv.net/gimg/www.off...67d2cc6266.jpg
sutphen 30 04-02-2020 10:13 AM
personally,I'd cut the upper manifold so the distr. cap fits and then weld up the hole.thats if you can't find a lower cap for that distr.
AllDodge 04-02-2020 10:33 AM
Change back to Delco EST
F-2 Speedy 04-02-2020 12:09 PM
can you run the crab style cap with this distributor ??
GPM 04-02-2020 12:18 PM
I don't know if this would work for you, https://www.jegs.com/i/MSD/121/8541/...All%20Products
ksalmine 04-02-2020 01:54 PM
I just paint parts, welding is not first choice. And upper intake may twist from welding.
I found crab cab also in internet, but it looks so low that it won't fit to hei distributor. Does anybody know the truth? I have one MSD billet hei distributor cap and it fit well to Holley distributor. Soif crab cap fit MSD HEI, it should solve problem
F-2 Speedy 04-02-2020 02:01 PM
Id call Holley Tech and tell them your issue and see if they have an answer....... I think there is a low profile HEI cap out there but dont have a part #
ksalmine 04-02-2020 02:05 PM
My worse english doesn't allow that but maybe I will mail them. Tried first here because somebody else may have had same problem before.
F-2 Speedy 04-02-2020 02:06 PM
that looks to be a good 3/8's of an inch from clearing
https://cimg5.ibsrv.net/gimg/www.off...cb78323d48.jpg
ksalmine 04-02-2020 02:11 PM
1/2" at minium so wires can pull off without remove plenum. water cut spacer flanges do the job but crab cap is most simple way if it fit
