I'd work harden those welds,ie,beat them almost flat w/ a hammer.then grind smooth
Originally Posted by sutphen 30
(Post 4736829)
cheers |
Mercury 525 EFI 502 CID Engine
I have 2 of the Mercury 525 EFI 502 CID engines I am trying to rebuild. I cannot find the serial number or model of engine in the specs label it is either gone or never been printed on it. I am trying to figure out which exact model and year the engine is to order parts for it. The Block has the numbers C272, C12561358. The cylinder head has the number 900 843425. The Intake: 12550669. The piston has the number 843302a1. Would appreciate any help.
Model: HP525 EFI Displacement: 502 C.I.D. Max WOT RPM: 4800-5200 Spark Plugs: NGK BPR6ES Spark Timing: Non Adjustable Fuel Octane: 87(R+M)/2 or 92 Ron International Engine Oil: Mercury/MerCruiser 4-Cycle 25W40 Engine Coolant: Dex-Cool Thanks |
| All times are GMT -5. The time now is 08:09 PM. |
