crank a 496ho without spark?
what is the easiest way to dissable spark to a 496 ? want to crank with no fire before first start up after winter nap
Why???? Pre-lube?? If that's all, then just fire it.
Prob more risk of damaging something like a PCM or engine electronics by trying to bypass spark. |
Pull your kill switch.
Run a lead from the battery to the starter motor
Unplug the crankshaft sensor, but why?
Dude, just pull the kill switch tether. It will turn over, no spark.
But from what you are describing you dont need to, just start it. |
Just pull out the oil sender and you can even use a hand pump to put in a couple of quarts of motor oil to oil prime your engine. I do every engine that way to oil prime the engines when needed but by using a air / oil priming set up like what Melling has.
Actually I am a fan of oil priming marine engines that sit for Loooong periods of time. Actually its not good practices to use the kill switch to crank over the engine multiple times using the 555 s ecms / pcms nor run any jumpers to persay to turn over the engine the engine however nor pulling connectors and letting them hang Also for the record a fair amount of OEM stock marine engines made in the past 17 years ---- pulling the kill switch will disable even cranking over the engine. Like I said some will not even engage the starter The best way to disable the spark and fuel is to pull their fuses and or relays. Problem solved. The MARINE OEM s have service bulletins all about this. |
Even for distributor engines - I use in the link below - pull out the oil sender out and prime away. This is the current way to oil prime engines -- If one has a distributor you will never go back to pulling that out and using a drill when you have this set up. I have been doing this for over 20 years now on marine engines and would never go back to pulling distributors if applicable.
https://www.summitracing.com/parts/m...hoChQ0QAvD_BwE |
Originally Posted by Keith Atlanta
(Post 4736071)
Originally Posted by Griff
(Post 4735996)
| All times are GMT -5. The time now is 12:51 PM. |
