-   -   Merlin 320cc, grumpy special head flow? (https://www.offshoreonly.com/forums/general-q/366160-merlin-320cc-grumpy-special-head-flow.html)
JaniH 05-04-2020 01:34 PM
Have a chance to buy these merlin 320cc iron heads, grumpy special casting. Ho does these heads flow? Going on top of 9.7 to 1 compression, 509cid engine with gm zz502 roller cam. Are these any better than merc stock rec-ports. These are virgin set but would be bowl ported with good seats.
sutphen 30 05-04-2020 09:10 PM
bring a sbc 1.50" exhaust valve w/ you,if you can run it thru the exhaust port,they can be made good.just have to watch out for breaking into the water passage by the short side radius.
hogie roll 05-05-2020 01:51 AM
Stan Weiss' - Cylinder Head Flow Data at 28 Inches of Water -- DFW / FLW Flow Files for use with Engine Simulation Software
articfriends 05-06-2020 10:55 AM
They need work, as cast they are barely better than stock,Id buy the EQs over them fwiw
