-   -   K Plane transom plate replacement (https://www.offshoreonly.com/forums/general-q/366206-k-plane-transom-plate-replacement.html)
formulavt 05-06-2020 11:55 AM
So i bought a used set of k planes, was sent some crappy pictures but was assured they are super clean....I know I know,lesson learned! So the transom plates are super corroded, bottom plates aren't too bad, pumps and lines are good. So i am wondering if I can just replace the transom plate and call it done, but the issue i am having is identifying a replacement part. The part number on the plate reads 107015, and I believe the manufacturer number is 841215c. My question is will any replacement transom plate work with my existing bottom plate and hardware??
smashm 05-06-2020 05:59 PM
How bad are they? Can't they be blasted, filled & painted?
