525 EFI #4 cylinder no spark >
Old 05-16-2020, 02:16 PM
Default 525 EFI #4 cylinder no spark
Iím really scratching my head here so Iím posting this to see if anyone else has had this issue and hopefully to learn us all somethin in the process. 2006 525 efi 396hrs. Whipple and heads done about 75hrs ago. Bought boat, fired up in driveway multiple times before going out on the water, ran great, have videos to prove it. First time out, second time getting to cruising speed all the sudden I hear solid alarm for maybe 1 second then port motor shuts down at about maybe 3000rpm, not fast at all. Since then motor starts hard, runs crappy etc, narrowed it down to no spark on cylinder #4. Iíve swapped plugs, wires, coil packs, and even computers with stbd motor. I didnít try to run stbd ecm on port motor though, only put port ecm on stbd motor and it ran perfect. Have not checked compression but there is clearly no spark with spark checker. Scan tool shows no issues, cleared old faults. I did notice timing advance on port motor is all over from 10-38deg, stbd is 8-13, but Iím assuming thatís port ecm trying to compensate idle for #4 doing nothing. Any ideas?
IGetWet is online now
Old 05-16-2020, 02:42 PM
Bad spot in wiring harness from ECM to coil?
PARASAIL941 is offline
Old 05-17-2020, 01:42 PM
That’s my next check, pin out from ecm to coils. But...#7 shouldn’t be firing either then, but it is
Old 05-17-2020, 03:57 PM
Valve could be sticking? Broken valve spring?
Tim
941 is offline
Old 05-18-2020, 08:58 AM
Could be, but would that cause no spark on that cylinder?
Old 05-18-2020, 09:13 AM
SB
Excuse me if I missed it, did you pull the plug , take a good look for damaged or missing ground strap ir electrode and change it anyway if looked okay ?An inline spark tester wonít light with a bad plug either.
SB is offline
Old 05-18-2020, 09:19 AM
Yea I’ve swapped plugs, even tried a brand new plug.
Old 05-18-2020, 12:10 PM
If you are getting a misfire code on the ecu yet it works at idle and other rpm's but misfires randomly then yes it can be a valve sticking or broken spring, if the valve is not sealing the combustion chamber it is a misfire. I believe on your engine you have more then one plug getting fed per coil. If that is the case and you are moving coils around, plugs, plug wires then the problem is in the cylinder itself, I feel
Tim
941 is offline
Old 05-18-2020, 12:31 PM
F-2 Speedy's Avatar
Could the crank sensor be the issue. I know seems odd only #4 would not fire
F-2 Speedy is online now
Old Yesterday, 09:51 AM
Yea, with the wasted spark system, if #7 is firing #4 should be as well right?
But the plot thickens. No compression on #6 cylinder. Hoping this has something to do with no spark on #4. Bent valve... When it rains it pours I guess
OSO Sponsor
OSO Advertiser
OSO Advertiser
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information
Copyright © 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
OSO Advertiser
