How to setting timing on a 1994 454 mag with thunderbolt V ignition
Who knows how to set timing on a 1994 Gen V 454 with a thunderbolt V distributor. It doesnt have a knock sensor and no purple/white wire to put it into base mode. only 4 wire coming out of the advance module. A purple wire to the + coil. A grey wire to the - coil A white/green and a white/red wire going to the the inductive pickup in the distributor.
Originally Posted by phughes69
(Post 4739956)
Who knows how to set timing on a 1995 Gen V 454 with a thunderbolt V distributor. It doesnt have a knock sensor and no purple/white wire to put it into base mode. only 4 wire coming out of the advance module. A purple wire to the + coil. A grey wire to the - coil A white/green and a white/red wire going to the the inductive pickup in the distributor.
| All times are GMT -5. The time now is 08:54 AM. |
