Need tuning help
Will I need less fuel , what about timing?
Can`t be too safe with THE RONA on the loose.. https://cimg9.ibsrv.net/gimg/www.off...6aa86edaa4.jpg |
Also with social distancing I want to be compliant so can anyone help with staggering a Flat Deck?
wouldnt you need them on the exhaust pipes also? they say that breathing out is as dangerous as breathing in.
You do realize you need to run alcohol now, so that your engines internals are sanitized...
Originally Posted by ICDEDPPL
(Post 4739992)
Originally Posted by f-2 speedy
(Post 4740049)
ff has a chain saw ??
LOL
This is my helpful idea. First, you need two N95 masks. With the forced induction, you will want the built in blow off valve that the N95 offers. Second, as long as both engines are from the same household you should be fine with the social distance. Good luck and as always stay safe! This is my helpful ideas. First, you need two N95 masks. With the forced induction, you will want the built in blow off valve that the N95 offers. Second, as long as both engines are from the same household you should be fine with the social distance. Good luck and as always stay safe! |
| All times are GMT -5. The time now is 11:42 AM. |
