-   -   Gasket sealer for Exhaust Manifolds. (https://www.offshoreonly.com/forums/general-q/36654-gasket-sealer-exhaust-manifolds.html)
Shooter 11-10-2002 06:58 AM
My merc manifolds show a little sign of weeping on the outside which means it is or will be doing it on the inside - I miss my Gils. Anyway, going to yank them and put new gaskets in. Should I use a sealant with the gaskets and if so what kind of permatex? Also, anyone know the torque specs?
Thanx
Ric232 11-10-2002 08:22 AM
Per the Merc service manual, the torque spec for the manifolds and risers 25 lb-ft. Be sure to use Merc OEM gaskets !! They are to be installed dry (no sealant).
RickR 11-10-2002 02:50 PM
I use a Permatex product called "Hylomar"
pachangalpina 11-11-2002 11:00 AM
If the sealing flange is pitted from rust/corrosion you may need to have the manifolds surfaced to keep them from leaking. You can surface them yourself if you have access to a large belt sander or take them to a machine shop.
Shooter 11-11-2002 11:07 AM
thanx guys, my friend also used a permatex product that was sprayed on the gasket. I don't think pitting is a problem, it's a 96.
