Mounting Extension boxes and Drives
I'm about to put my boat back together after a 2 year layup. The engines are 540's, 700hp@. It was winterized properly and oils changed before layup. I am guessing that I will have to drain the fuel tanks, change filters and pull carb bowls before attempting to start. My bigger issue is I need to re-install the extension boxes and drives and I have never done that before so I don't know how to properly seal them, any torque specs for the transom bolts etc.. I have new foam seals but should I also use any type of sealant on them? Any more advice would be appreciated, THANKS!
I would torque the extension box in the same pattern, number of passes and torque the transom assembly calls for.
what box and drive do you have? what engine mounts? i would also look real hard at alignment. |
Originally Posted by outonsafari
(Post 4743427)
25 ft lbs for ext boxes and pretty much anything that is bolted through the transom
https://cimg3.ibsrv.net/gimg/www.off...330a578c9f.png |
| All times are GMT -5. The time now is 05:48 PM. |
