Engine and Stern drive Weights
I’m doing some pondering...I’ve got a 1986 mercruiser 330 with borg Warner transmission and TRS drive, I’m thinking of swapping in a pair of aluminum small blocks with alpha drives...
is there a site or table that lists weights? Or does anyone have an idea? |
Go with Bravo drives if you do the swap. Alphas will only handle 300hp and not as much torque.
Probably will be about 300-400lbs a side lighter |
| All times are GMT -5. The time now is 11:41 AM. |
