-   -   Spark plug and timing questions '90 454 Mag (https://www.offshoreonly.com/forums/general-q/366976-spark-plug-timing-questions-90-454-mag.html)
AllDodge 06-18-2020 08:48 AM
Champion, AC, NGK just like ford, chevy, dodge
Do agree don't run larger gap
TomZ 06-18-2020 10:42 AM
I thought the Delco marine plugs were no longer available,though looking at their site...I guess they're available again.
I've been using Delco commercial series plugs in mine.
kdshouston 06-18-2020 06:48 PM
The oil is only on the threads. The tips look okay, no trace of oil. There is one plug that has a little bit of excess carbon build up.
I already have the champion plugs in hand. I also got a new cap rotor and 30 OHM resistance 10 mm wires. I might pick up a hotter coil.
Could I re-gap the plugs to .045 and work with them through the season? Thanks for everyone's input.
AllDodge 06-18-2020 07:35 PM
First why do you think .045 gap or hotter is needed?
The extra gap without the need for it just causes issues. Your motor was designed and built for a given set of parameters. Changing those parameters causes other issues/concerns. Running a hotter plug or more gap and not changing things like using higher octane fuel or changing timing can destroy your motor.
SB 06-18-2020 08:54 PM
The factory e-core coil on these 454/502MPI motors are extremely strong and will not die like a My Spark Died coil or etc.
.035-.040 gap.
Will fire a supercharged engine too, no sweat.
worry about something else. :)
