What idle speed is too high for a Bravo >
Old 06-18-2020, 03:51 PM
I do recall that during dyno testing the carb guy at the shop made an alteration to the secondary linkage to make the secondaries come in a little sooner than they did in stock form. He did this to help cover up a lean spot when running at a fast cruise speed. I am going to take a close look at this to see if it might be binding.
Budman II is offline
Old 06-18-2020, 05:42 PM
Ayuh,..... Like SB said, the throttle cable/ linkage should be adjusted to hold a slight tension, against the idle adjustment screw,......
Bondo is offline
Old 06-18-2020, 07:13 PM
Originally Posted by Budman II View Post
Do you think it might be the secondary linkage binding, or maybe the secondary throttle plates being open a little?
Open a little is what I was thinking. Since you said someone has messed with it I would look there. I assume it is Holley with mechanical secondaries, if so the link that pulls them open also pushes them closed.
liberator221 is offline
Old 06-19-2020, 11:29 AM
OK, ran it on the hose this morning. Was still sticking without throttle linkage installed, so the problem was with the carb. Pulled it off and examined it closely. Didn't see anything obvious, but I could see a little bit of a carbon line where the secondary plates had been riding in the bore, and it looked like the transfer slot could be getting exposed a little. So I backed off the little limiting screw for the secondary a quarter turn, and I took the return spring one more trip around to give it a little more tension. Cleaned all the carbon off the bore and made sure I couldn't feel a step in the bores. Put the carb back on and checked to make sure there wasn't any interference with the gaskets or the throttle bracket underneath it. When I started it, it still seemed to hang up slightly with no return spring or linkage installed, but once I put my spring and the throttle linkage back on, the problem seems to be solved. Going to water test it this evening to see how it does. Thanks for all the replies!
Old 06-19-2020, 05:45 PM
TomZ's Avatar
It shouldn’t need a spring to keep it closed. The cable should be able to close the throttle body. Sounds like something is binding... replacing the baseplate is not out of the question and not that expensive. Just my thoughts.
TomZ is offline
Old 06-30-2020, 10:30 PM
mcollinstn's Avatar
Cable adjustment.
Disconnect cable from carb. Set idle speed with "stop screw".
Now, adjust cable so that when the throttle lever is back at idle, the cable pushes back a bit against the stop screw.
Then, push the throttle lever wide open. When the lever is at wide open, carb linkage should also be fully open. If not. See if you have stop screws on the helm lever. Or maybe move the cable attachment to a hole closer to the shaft centerline.
mcollinstn is offline
The following 2 users liked this post by mcollinstn:
mike tkach (07-01-2020), ThisIsLivin (07-01-2020)
OSO Sponsor
OSO Advertiser
OSO Advertiser
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information
Copyright © 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
OSO Advertiser
