-   -   Hard Storage for the engine compartment (https://www.offshoreonly.com/forums/general-q/367763-hard-storage-engine-compartment.html)
ThisIsLivin 07-30-2020 02:48 PM
I have a single engine boat and just removed 2 ginormous sub's out of the engine compartment. I'm looking for durable hard storage containers for my tools, spare parts and cleaners. Checked a few sites and can't find anything. I need something that is extremely durable, I have been known to run in extremely rough water. I need something that can be bolted down with a cover that can be secured. I knew if anyone would have some good ideas they would be on here.
Baja Rooster 07-30-2020 05:27 PM
I had a local shop bend up some 1/8” diamond plate aluminum into boxes for my bilge. Works like a charm.
You can’t really see the port side but those are the ones that hold the tools and spare parts.
https://cimg0.ibsrv.net/gimg/www.off...69b71969a.jpeg
ThisIsLivin 07-31-2020 09:02 AM
I was hoping for something commercially available. I have some white storage bins that are fairly sturdy but that would look pretty hokey.
Unlimited jd 07-31-2020 09:13 AM
I bolted down the “rigid” case from Home Depot. Water resistant and very strong
ThisIsLivin 07-31-2020 10:48 PM
I took your idea and did a search online and found something that will fit that is a copy of your idea. I’m going to check out the Rigid Tool box as well.
ThisIsLivin 09-15-2020 05:27 PM
Here's what I ended up with, worked perfect. I used rubber grommets for the screws holding them down so they are sealed and weather strip around the inside lip so they are water tight.
https://cimg2.ibsrv.net/gimg/www.off...742ad441aa.jpg
https://cimg3.ibsrv.net/gimg/www.off...648194d5b8.jpg
RSCHAP1 09-16-2020 10:47 AM
Milwaukee pack outs
ThisIsLivin 09-16-2020 11:26 AM
Originally Posted by RSCHAP1 (Post 4757538)
Milwaukee pack outs
I looked at those, but I needed something larger and I wanted it to be metal. I keep spare octane booster and oil in there so I wanted it to be fire proof. I keep a pretty complete tool set with enough spare parts to solve most issues. I boat out in the middle of nowhere and if I get stranded I may be out of VHF and Cell range and there may not be another boat coming by until next spring. There's more boat traffic in the middle of the Atlantic then where I boat.
