Whippled 509 quits over 1000 rpm
Twin whippled 509s. Port motor starts, idles and shifts fine but once you push throttle over 1000 rpm it coughs, sputters and dies instantly or sometimes it may lose rpm down to 3-400, catch itself and slowly come back up to idle. They have new cap, new rotors, swapped fuel pumps, swapped coils and swapped ECMs. They have thrown no trouble codes other than low voltage on the throttle body sensor. Also had the fuel tank drained and cleaned. All fuel filters are clean or new. Any ideas?
I would start by checking fuel pressure
you can pull the IAC and cycle the key on and off to see if its functioning normal..........I had one do similar issues engine would die when put in gear under load, swap the IAC's see if it follows...........what blowers are these 3.3 ?
they'll fire just fine up to 70psi,i tested mine up to 100psi,had to tap start them to fire,but once going,they did fine.I was just testing them to make sure they were fine.
