-   -   Hesitates around 2000-2500 rpm (https://www.offshoreonly.com/forums/general-q/368005-hesitates-around-2000-2500-rpm.html)
Jase 08-14-2020 05:12 AM
Hello my 89' 7.4l merc ( 4 barrel) in my formula 242 sounds good at idle and over 3000 rpm. But sounds like its missing at lower rpms. However idles and starts fine . Its not at an alarming level ATM but needs to be fixed. Any ideas ? Thanks
Helmwurst 08-14-2020 06:41 AM
What plugs are you running?
Jase 08-14-2020 08:40 AM
Don't know, I just picked up this boat. I went through a similar issue with my previous boat, but it was much worse than this one. A wire was toast. I imagine its an ignition part or fuel part. I was hoping the oddness of it only showing up in mid-range rpms someone could figure a likely culprit. I really dont want to again buy every ignition or fuel part until the problem disappears.
SB 08-14-2020 10:50 AM
So, maintenance is out of the question ?
Not even going to look at the plugs for some insight ? And date codes on wires if Mercruiser wires ? Inside cap ?
Knot 4 Me 08-14-2020 12:01 PM
I wouldn’t buy parts and toss at it I’d start diagnosing the issue and eliminating possible culprits. I’d start on the ignition side.
Jase 08-15-2020 10:57 AM
Maintenance is not out of the question. I just dont want to buy a ton of parts and hope for the best. The wires are mercruiser red, 2096. No idea of when they were installed. I would surely do plugs and wires. The coil looks brand new. Since the issue is only mid range rpm. I am suspicious of the fuel/carb side since that is variable depending on engine temp and demand. The ignition side I would think would show the problem regardless of rpm
speicher lane 08-15-2020 11:36 AM
your issue can definitely be a result of Ign or fuel delivery...but you have to do due diligence and inspect the obvious (resistance check the wires, inspect cap and plugs etc)
I have seen a few issues where the carb needed a heavy cleaning/rebuild as there was issue with fuel quantity as the secondaries transitioned
