-   -   Replacement Heads for 454 Mag (https://www.offshoreonly.com/forums/general-q/368084-replacement-heads-454-mag.html)
JonnyD757 08-18-2020 01:20 PM
Cracked the exhaust seats on my cast 454 Magnum heads. Looking for a good replacement suggestion, Al or FE.
SB 08-18-2020 01:21 PM
Mark IV, Gen V or VI ?
Where are you located ? Shipping cast iron behemoths matter $$$ wise by how far.
resurrected 08-18-2020 01:44 PM
Closed cooling? Fresh water or salt?
Used or new?
Used, Sick Stinger on here would be the guy
JonnyD757 08-18-2020 01:45 PM
SE PA. Not sure what Gen the block is. They are rectangular port heads. Guy i bought it from said it was the Mercruiser 365 Mag 454
JonnyD757 08-18-2020 01:51 PM
Fresh Water, may see salt once or twice a year. Looking for new if possible
Baja Rooster 08-18-2020 02:48 PM
Is ADK61 still around? He was selling complete heads well set up for marine use. I believe the feedback was consistently positive, which is rare in this industry.
Griff 08-19-2020 01:12 AM
If it has a fuel pump mount location on the engine block, it is a Mark IV.
If it does not and has stamped steel timing chain cover, it is a Gen V. Also if the head casting numbers end in 088, they are Gen V.
Rookie 08-19-2020 06:34 AM
FE = Engine Quest heads (direct replacement)
AL = Promaxx (economical good aluminum head)
Get in touch with JimV on the board and he can set you up.
