-   -   525 shutdown issues (https://www.offshoreonly.com/forums/general-q/368187-525-shutdown-issues.html)
Jeff holland 08-24-2020 08:07 PM
525 shutdown issues
I have twin 525s and when I run over 4700 rpms for 5-6 miles one or the other will out of nowhere return to idle. I can bring it down to idle go to neutral then back in gear and works just fine. If anyone has an idea on what the problem is I would love to know
imartin 09-01-2020 01:10 PM
you getting any alarms? Any fault codes?
AllDodge 09-01-2020 03:01 PM
Happen to have a single line feeding both?
Does it do it again or just the one time?
Jeff holland 09-01-2020 05:17 PM
No it happens at random time twice on port once on starboard on separate lines
AllDodge 09-01-2020 05:25 PM
As imartin mentioned, any alarm?
Do you hear beeps when key is turned ON prior to start?
What's the engine serial number?
